Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Tools and Garages
Tools and Garages This is a place to share about the tools and workspaces used to craft your latest masterpiece.
  #16
Old January 23rd, 2018, 05:48
zr2toxj's Avatar
zr2toxj zr2toxj is offline
Re: Starter Welder
I was kind of in the same boat last year. I had done some stick welding in the past, but wasn't very good at it. I looked at many different welders and decided to blow my budget out of the water and get a Millermatic 211. I am very happy I did. I used the flux core first, before I had a chance to get some C25, and it works, but is much harder to get a clean weld.
With C25 gas and the .025 wire I have butt welded 18 ga sheet metal and spot welded 22ga. I've also used the .030 wire on 1/4" to 3/8" and it did great in one pass. The Auto set feature is spot on. I also like the inverter technology because it only weighs 38 lbs. I've packed it up many times and thrown it in the Jeep.
EDIT:
I bought mine through Cyberweld and they gave me a discount and a free Jackson auto darkening helmet. Definitely get one of those, it makes a huge difference.
Old January 24th, 2018, 08:59
denverd1 denverd1 is offline
Starter Welder
It's true, auto helmet makes a big difference
Sent from my SAMSUNG-SM-G930A using Tapatalk
Old January 24th, 2018, 09:55
Re: Starter Welder
Originally Posted by Kyle96 View Post
Check out the eastwood 135 mig/flux core welder. I have it and it does pretty well especially on 1/8"-1/4" thick material, not so great on the thin stuff, but for the price overall i am very pleased.
that looks like it would be the best low end welder
Old January 31st, 2018, 15:15
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Re: Starter Welder
Agree on spending a little extra coin and getting a decent welder.
Old June 17th, 2019, 13:07
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Re: Starter Welder
Originally Posted by zr2toxj View Post
EDIT:
... Jackson auto darkening helmet. Definitely get one of those, it makes a huge difference.
Definitely agree on the Jackson helmet.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 Stock-ish
SoCal Chapter Past President
Old July 6th, 2019, 15:09
Bent's Avatar
Re: Starter Welder
Agreed, even if its gently pre-owned.
Rate This Thread:
Mini-Welder 115v welder/carbon torch, Front OEM skid and other stuff Bent SoCal For Sale 9 January 22nd, 2016 16:17
Ignition? Starter Relay? Starter? RebelXJ OEM Tech Discussion 11 January 18th, 2012 11:03
starter went out, fixed it, now starter doesnt get a signal?? HELP!! DangerousJordan OEM Tech Discussion 4 February 19th, 2007 17:43
ready welder/century welder/portable welder? Redcbr007 Wanted: Private Party Only 1 June 6th, 2004 22:01
