Achmed
- Southeast US
Will work with ANY year XJ. This kit fits very nice and will pull WAY more CFM than the mechanical clutch fan assembly. This kit consists of:
(1) 14" curved blade 2200 CFM electric fan
(1) 40 amp relay (pre-wired)
(1) Thermostatic control switch to set when fan comes on/off (pre-wired)
(4) Push through zips to mount fan to back of radiator.
It is all pre-wired and ready to install. All you have to do is remove your clutch fan, run a power wire and a ground wire, mount the fan, mount the relay and go. I have about $120 in this kit and will let it all go for $60 shipped anywhere in the Lower 48 states.
