Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Comanche MJ (1985 - 1992)
Jeep Comanche MJ (1985 - 1992) Jeep's Cherokee-based compact pickup technical forum.
Old January 12th, 2020, 13:07
blackjeepltd's Avatar
blackjeepltd blackjeepltd is offline
Gas tank skid plate
Does anyone have a gas tank skid they would want to part with for a short bed Comanche? I have the plastic splash pan but want something a little beefier for wheeling. I would buy an aftermarket skid but have been unable to find anything. Any suggestions or does anyone have an extra one they want to sell? I知 located in ohio. Thanks , justin
Old January 12th, 2020, 15:55
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Re: Gas tank skid plate
Of you haven't yet go look at comanche club. It's the MJ forum they'll get you squared away.
88 MJ truggy, 4.0HOybrid AX15, NP242 **Being built**
Mods: D44 w/ 4.30's, ARB front and Auburn rear, 33's
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old January 13th, 2020, 04:33
Thanks I知 not as familiar with them I figured I would
Check out here first much more familiar with this site been a member for
Much longer on here. I値l check them out thanks
Old January 13th, 2020, 12:49
smokeyyank's Avatar
Jeepoholic
No worries, anything MJ related that is the spot to go. Even in general that group is awesome.
04 WJ, 4.7HO
Old January 13th, 2020, 23:52
Ralph77 Ralph77 is offline
I was curious if a XJ from that era was the same skid as a MJ.
It is not. But also came across the fact that there is one for the 6' bed and another for the 7' bed.
I believe these to be the part numbers.
52001806 PLATE, Skid, w/7 ft. pickup box
52002810 PLATE, Skid, w/6 ft. pickup box
Old January 15th, 2020, 08:21
High2by's Avatar
High2by High2by is offline
Jack of all trades
The XJ and MJ tank skids will not interchange. They are totally different but you are correct in the differences between a SWB and LWB.
Originally Posted by Bent View Post
If you run summer oil in the winter two things will happen:
-your engine timing will be off because of the shorter daylight hours.
-Your AC will work fine with summer oil but your heater/defrost requires winter oil.
OEM XJ gas tank skid plate $150 chickenbot Red River Chapter For Sale/Wanted 8 January 19th, 2019 15:11
WTB Skid Plate (Gas Tank) SID'S Garage NAC Classifieds 4 May 19th, 2009 11:10
Gas Tank Skid Plate jfiscus Wanted: Private Party Only 8 April 11th, 2005 07:39
