kerriliane
- Langley
I've got a 1990 xj...
Starting on Friday I noticed it was sitting at 1000rpm in D and 2000 in P or N.
This isn't happening all the time. It usually sits at 5/600 regardless of the gear when stopped. It also pulls more and is hard to brake when its idling higher.
This happened two or three times on Friday and it doesn't start and run high it just starts doing it randomly during the drive.
Today now, twice, it has started fine I've driven 100ft and its stalled.. and then when I start it again it idles at around 100rpm for a couple mins then is back to normal....
I replaced the 02 yesterday and fuel filter last week all the fluids are in good shape and the only coolant issue I know of I a very small crack where the upper rad hose goes in. Its in that area, it doesn't leak coolant though.
Please help!
-kerri.
Please help!
-kerri.
