Old November 25th, 2006, 18:15
xrayjeeper83 xrayjeeper83 is offline
Temp Gauge
I went to the junk yard today and I scored a cluster with gauges for only 15 bucks . But the temp guage doesnt register. I installed a new sending unit, and when I am turning the Jeep on the gauge will go all the way to 260 and then back to 100 but it does that wether its connected to the sender or not???? do yall think its a bad gauge or something else. how can I test for a bad gauge?
Andrew
Old November 25th, 2006, 19:03
bajacalal bajacalal is offline
Re: Temp Gauge
What kind/year of cherokee is it?
Did you:
1.) Get the correct sending unit and specify that you wanted one for a cherokee with gauges, absolutely not one for warning lights when ordering it?
2.) Get the right sending unit and not another sensor. The sending unit goes on the back of the head (on some years) and is a small one wire unit, not the larger 2 wire affair on the thermostat. That only is for the ECU operation.
Old November 25th, 2006, 19:14
Re: Temp Gauge
I pulled the one in the thermostat it self. Thats the wrong one????
Andrew
Old November 25th, 2006, 19:15
Re: Temp Gauge
Oh and I have a 94 and pulled a cluster from a 94
Andrew
Old November 25th, 2006, 19:22
Re: Temp Gauge
Andrew
I'm afraid so. At least you now have a spare coolant temperature sensor. The "temp gauge sender switch" is smaller and at other end of the cylinder head, sort of next to the brake booser.
Old November 25th, 2006, 19:27
Re: Temp Gauge
Yep thats what I did. Once you said something I goggled it and found a picture so I know what to fix.
Andrew
Old November 25th, 2006, 21:12
Jess Jess is offline
Re: Temp Gauge
careful if you pull it from a salvage yard...they break really easily (use deep socket). Myself and many others have had problems with temp sending units from chain stores. Your best bet is to find an OE one from salvage or go to the stealership.
Old November 26th, 2006, 04:50
ratherbcamping's Avatar
ratherbcamping ratherbcamping is offline
Re: Temp Gauge
None of the chains I went to had a temperture sensor, they wanted to sell me a temperture switch for the idiot light. Bought one from the dealer for $17.
Old November 26th, 2006, 14:09
Re: Temp Gauge
I just bought one from autozone for 8 bucks. Im going to let it cool and then see if I can get it installed. Thanks for the heads up about it being easily broken
Andrew
Old November 26th, 2006, 15:54
Re: Temp Gauge
Let us know if it works. Autozone here does not carry the right one. They only carry the switch. They told me the one for the gauge isn't even in their system.
Old November 26th, 2006, 17:18
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
Re: Temp Gauge
The sensor on the thermostat housingis for the electric fan. Older Cherokee's didn't have this sensor, or at least it wasn't on the thermostat housing.
The temp sensor for the gauge is practically below the MAP sensor.
Old November 26th, 2006, 18:27
Re: Temp Gauge
It seems to working fine. Runs just a hair above 210 and a good radiator flush should help that.
Ya Blaine I figured that out after going and buying the one that was in the thermostat housing LOL guess that what I get for not doing research first.
Andrew
Old December 27th, 2006, 06:20
dspilot dspilot is offline
Re: Temp Gauge
I just replaced my sneding unit with one from Autozone, and still get nada on the gauge. Should I get one from Jeep and see if that works, or is there something else I should try?
Old December 27th, 2006, 06:22
Re: Temp Gauge
I always forget to add the specs.
1996, 4.0, 4WD
and it was indeed the sending unit that I replaced (back by the firewall).
Old December 27th, 2006, 08:15
Re: Temp Gauge
You probaby got the one for the switch. The Autozone here couldn't get the right one, so I went to the dealer. It was 17 bucks.
Tom
'94 XJ Did the gauge swap, temp gauge doesn't move while driving caspergotaz28 OEM Tech Discussion 1 April 24th, 2005 15:08
Temp gauge way off? brtb OEM Tech Discussion 13 July 14th, 2004 08:00
Temp Gauge 2wdxj OEM Tech Discussion 3 June 14th, 2004 20:39
Temp. Gauge jeepguy97 OEM Tech Discussion 1 March 18th, 2004 17:13
Screwy Temp Gauge Mikes92LTD OEM Tech Discussion 1 January 24th, 2004 21:29
