Old April 6th, 2003, 19:07
Pale Horse Pale Horse is offline
I have not Confirmed, or I used a BAD email Addy
Location: Springfield, Illinois. Home of good ol' Abe Lincoln, flat ground, and corn.
Question t-case shifter...
How does one get the handle off the t-case shifter? Is it glued, screwed, welded ?
Old April 6th, 2003, 19:39
XJ_MAC's Avatar
XJ_MAC XJ_MAC is offline
NAXJA Member #184
My 97 FSM doesn't indicate that it comes off. It's removed along with the lever assembly.
Old April 7th, 2003, 20:38
Backdraft's Avatar
Backdraft Backdraft is offline
What I did was put it in drive (engine off) and yank reak hard and steady on it. Pops right off, and pushes right back on. Just be careful when pulling it off! (might pop yerself in the grille)
Old April 7th, 2003, 20:40
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
You talking the auto trans shifter Backdraft? He was asking about the Transfer case shifter. (the clue was careful or it'll hit you in the face..not that that's happened to me...twice...really!)
Prior President & Prior SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old April 7th, 2003, 20:44
Backdraft's Avatar
ooooooooooooooooooops. sorry bout that, guess i need to start reading
Transfer Case Drop deepcdiver Modified Tech Discussion 10 November 25th, 2006 10:26
transfer case woes,.. BILLXJ Modified Tech Discussion 15 May 24th, 2005 14:25
Transfer case spline count info wanted. lunghd OEM Tech Discussion 4 May 2nd, 2005 18:54
Tranny/X-Fer Case mounts Matthew K OEM Tech Discussion 9 June 20th, 2003 06:58
..NP 231 transfer case studs,.. BILLXJ Modified Tech Discussion 4 May 8th, 2003 12:06
