Swamper35
- Lower Coverdale, New Brunswick
88 xj with a non disco front D30. I am running clayton short arms and 4.5" Re springs. The shocks are superlift cheapo's and the problem I am having is that the lower shock bushings only last about 2 weeks . The 2 weeks would not be very many miles, maybe 300-500 max. Is it the cheap shocks or is my junk out of wack?
While making a post I also figured I would ask about my rear shaft. I am running a 231 with a sye and a stock front drive shaft which I had lengthened. Now the question is how much inward movement should the slip joint have when the jeep is just sitting on its own weight? Right now there is about an inch of the small shaft in the slip joint showing and I am worried that it is not enough.
