The power setting is the norm for most newer XJ's (HO - newer) that don't have the switch. The comfort mode has a smoother shift at the cost of more tranny slippage/heat build-up.
In stock configuration with 205 75 tires I didn't notice much change; however, with 32" BFG's and stock gearing (3.55) I always leave mine in power mode and 3 (the difference now is more noticable and I want less stress on my tranny).
I also notice on my 89 4.0, AW-4 that the speed at which the trans shifts into 4th and locks the converter is altered by 10mph. I generally run in power mode all the time because I don't like the short 1-2 shift in "comfort."
I noticed that, in power, going down steep hills in 4th gear, the TC lockup cycles annoyingly. If I downshift to 3rd or put it in comfort, it doesn't happen.
