Looking for more power with out getting crazy?
Want something with more power that bolts right on and is easy to find?!
We found out that a 2001' 4.7L Grand Cherokee runs a pump VERY similar to an XJ. The pump bolts right on with just changing the fitting for the high pressure line. Then a plug must be put on the extra return line.
Here is the best part, The 01' 4.7L runs a Hydraulic cooling fan off the PS pump. Because of this the pump is higher volume and pressure.
When the 01' Grand Cherokee pump is installed in an XJ the power increase is insane!
We can turn 33 swampers with a pinky finger, buried to the rock rails in the snow.
I am going to have to convert my 87' this way too.
Trust me, you will NOT be disappointed with this POWER mod.
XJR
XJR
