Clayton Off Road
Clayton Off Road
- East Haven CT
XJ Short Arm Kits from Clayton Off Road
Clayton Off Roads package deal lift kits are specifically designed to offer the best all around performance. This kit is put together using only the highest quality parts, and vigorously tested to meet our stringent requirements. Because this is a package deal lift kit, you know that everything is going to properly work together, to give you the best performance possible. Making bulletproof arms is our name to fame and we back that with our lifetime warranty. But that’s only one step of the equation.
When this package deal was put together we had one main goal in mind. We wanted to build the strongest, most reliable lift kit on the market. Price is important, but quality has to be a priority. Ease of installation is also very important, but strength and reliability has to be above the rest. If you save a few hundred dollars, and it falls apart in 6 months, that’s not saving money. These are all items we thought about when designing, installing and testing our lift kits. Our obsession to details, is what brings you the best riding, strongest most reliable lift kits on the market, period.
This bolt on 4.5 inch lift kit uses the same high quality coil springs, rear leaf springs, DOT approved brakelines, adjustable trackbar and double sheer bracket, swaybar disconnects, front coil retainers as our long arm kits. The biggest advantage with this lift kit is our heavy duty control arms. This kit comes with adjustable upper arms, that feature Currie Johnny joints allowing you to properly adjust your caster angle. Because many of these parts are also used on our long arm kit, upgrading is fairly simple. Many of the items can be reused, saving you time and money.
This lift is intended to run 31 inch tires, and does require a CV style driveshaft to eliminate any driveline vibration.
Check them out here: Clayton Off Road XJ Ultimate XJ Short Arm Kit
This kit includes:
Part # Description
1100108 Front Spring Retainer Kit
1201207 XJ 7 Degree Shim (pair)
1201304 XJ U-bolts ( set of 4)
1300103 DOT approved stainless steel brakelines
1505500 XJ 4.5" Front coil springs (pair)
1601400 XJ 4.5" Rear Leaf Springs (pair)
1800100 Short Lower Control Arms
1800101 Short Front Upper Control Arms
4500100 Adjustable trackbar
4500400 Trackbar Bracket
JKS-2001 JKS Swaybar disconnects
5101004 *OPTIONAL* XJ 4.5" Package deal (set of 4 5100 Series Shocks)
5601004 *OPTIONAL* XJ 4.5" Package deal (set of 4 5160 Series Shocks)
Alex
Marketing Director
Clayton Off Road
