sardo_67
- western CT
well figure i'd throw this up here on the off chance someone wants it.
HP D30 housing sand blasted clean then painted
new 4:56 gears with rebuild kit done by local forum guy (customcreations)
new Aussie locker
New Clayton high clearance bracket kit with truss
New Clayton WJ high steer link kit with TREs
New Crown upper/lower ball joints
WJ conversion done right with new everything (calipers, pads, rotors)
New Timken TJ unit bearings
New tube seals
New Chromo Shafts with 760s
uhhhhh maybe 15 miles on it
done by myself and Matt at Clayton last summer when i figured i'd run a 30 for some reason, lost interest in this, never went further than a trip around town once or my driveway, just needs a good diff cover then bolt in and go.
i can add in that track bar if you need to convert over to a straight one or work with you on what you'll need to run it.
shown without the new steering links.
welding the WJ spacers on the correct way with an oven and TIG to prevent the cast metal cracking.
oh ford 9 with a locker and new shit too if anyone wants it, bolts into an XJ. $700
new Aussie locker
New tube seals
