Re: WJ Knuckle Swap... The CORRECT way!
Nice writeup, but as others have said the spacer is needed for a reason.
Well what is it then?
The center line of the u-joint (or RCV in this case) is right where it needs to be. I did the measurements and from what I could tell, they are the same. If there was a difference it is definitely not a 1/4". The JKS spacer was designed with the late model guys in mind. You need it if you have the 00 or newer unit bearings or the rotor won't fit in the caliper bracket.
Now... all that being said, I haven't tried it with u-jointed shafts. But The RCV shouldn't be any different. The shaft didn't move forward or back when steered, which means the center line of the joint does indeed line up with the axis of rotation between the upper and lower ball joints. Also, think about it... the inner c's are the same between the WJ and XJ/TJ/YJ. Also, the stubs are the same, as well as the distance between the unit bearing mounting flange and where the axle meets the splines, so why would this cause the u-joint to be in the wrong place? It wouldn't. But just to satisfy those who still do not believe, I will be doing the swap on a u-jointed axle in a couple of weeks, and I will post up findings then.
So for those of you who disagree with me, you can do it you way and stack washers and hack it together unsafely. Not my ass in your rig when the rotor cracks and flys apart.
For those of you who have valid questions, I will do my best to answer them.
Ball Joints: Uppers are the same between WJ and XJ, lowers are WJ. The taper is a different angle according to Moog.
No this is not the LS2 XJ, he got Reid Racing Knuckles and is running REAL Dana 44 outer parts, not hybrid stuff like this. This was a custom housing that I built that is indeed TJ Rubicon width and used a High pinion Ford Center section, 1/2" wall 2.75" DOM axle tubes, and Jeep Dana 30 inner C's bored out to 2.75".
Like I said, I am doing another swap on a TJ Rubi housing that is still running stock shafts. It is in another XJ and he has the pre 98 unit bearings so basically the same setup we have here. If there is an issue I will let you know... but there wont be!
