I wouldn't go Durango box.
I'm hearing goods and bads about it.
Mostly I'm hearing the change isn't enough of an upgrade to make the job worth the work.
Have you had one? What was your experience?
Still held up waiting for the ball joint press to become available from Autozone.
I'm considering buying one.
All the research I've done is suggesting to go with the OTC press which is right under $200 with the Jeep/Dodge adapter.
Money I'd rather not spend on a tool that I'd use so infrequently...
Do you check O'reillys? They have a tool loan also
I'm about one beer from doing a relief cut and moving on.
