I have found over the years that the most common thing causing lack of heat is a heater valve that either isn't being activated (lack of vacuum/bad switch) or a bad valve. Other than that, it normally is a plugged heater core if there is zero heat coming out.
View the position of the lever on the heater valve with the engine off for a few minutes. Then start up the engine and put the controls to heat. You should see that the lever has moved. If it has not, grab a pair of pliers and see if you can actuate the valve manually. If you can, rig it to stay in that position with a tiewrap or some safety wire (redneck bailing wire).
