98xjjeeper
- nc
Sorry now I'm getting confused, I was thinking control arms this whole time then I realized we were talking radius arms so I looked it up to refresh my piss poor memory and this is what I keep seeing..Is that not a control arm?
Yes they are normally called control arms. Two lowers and an upper that attaches to one LCA. That is the same as a wristed radius arm setup, only one side keeps the axle from twisting the the other side just locates the axle. Often people miscall that a three link, since there are only "three links" but it isn't, its a wristed radius arm. You end up with great flex but you still have caster issue and the problem of it lifting the front end under a bind or climb. Three link is the way to go without a doubt if you want the best offroad performance, no binding, no axle wrap because you use hard joints, no lifting of the frontend on climbs and when the front end is in a bind. It also handles amazing onroad because of the same reasons. Those who say the radius arm setup is great on and off road compared to a 3 link haven't run a 3 link or a properly setup 3 link. Yeah it will drive fine and has been used for years from the factory but its not the most ideal. Its just a cheap and easy way of having longarms.
