BALTANAKT
- Berthoud, CO
So I've got a '91 Cherokee which I am sort of treating as an OEM+ build. I want to keep it looking factory and I am a total idiot when it comes to axles. Mine are super rusty and have been wanting to pull them out and redo them at some point, which brings up the question of whether I should replace them.
As I understand it, the rear is Dana 35, which is kind of weak. Does that mean the front is also a 35 or is it a 30?
I've installed a 2" OME lift, 31" duratracs, JKS track bar.
My intentions are to keep the thing in good shape forever, use it for road trips, camping, running trails (moderate at most), pulling a trailer once in a blue moon and a little farm work on occasion (like pulling stumps). I plan to build a hidden winch assembly and maybe add a locker or two eventually. Also considering adding discs to the rear.
So on to my questions...
Should I stick with what I have?
Would the Dana44 or C8.25 be advisable?
Are they all a straight swap or do I need an axles from a certain make/model/year?
Do people usually run the same thing front and back?
Anything I am missing?
