Frank Z
- Colorado Springs
Only a crazy-man would even attempt that!
Since I have literally collected the parts for this swap... dumb questions:5.9 now installed and running superb, a few odds and ends to tie up and she'll be ready for the trail.
I used a 5.9 from a 1500, 46RH and a 231.Since I have literally collected the parts for this swap... dumb questions:
will it fit under the stock hood?
how much lift is necessary and how much was your oil pan-axle clearance affected by the swap?
I'm gonna make the damn thing fit no matter how many deadblows, BFHs, and shoehorns I have to use, just curious what I'm getting myself into here... bloose from the MWC did one but the more info I can get, the better.
no tps test. and i heaved the old axle housing. LOL.I can't address the second issue. Hopefully you still have the old axle for comparison.
As for the first issue; did you test the TPS?
I sent you a link, where you can download a copy of the RENIX Manual. Start boning up on the diagnostics. If you can't find an analog Ohm Meter, I have one here.no tps test.
If that is the case, I have an extra sitting here. It would cost you a drive to Golden.Issue one sounds like a O2 sensor.
I thought the ZJ 30 was just a regular low pinion and the WJ was the super 30... I know the ZJ uses the same balljoints as the XJ and the WJ uses super 30 balljoints.Issue one sounds like a O2 sensor.
Issue 2..not all d30s are the same
the ZJ d30 is different from the TJ and both are different from the xj d30
The zj is low pinion and has a long pinion shaft. Jeep dubbed it a super 30. Hence the problem with the driveshaft.
The tj used a super short pinion shaft
