vaccuum disconnect D30 gasket
bigsky
Victorville, Ca.
Need the part number can't find one online, I live in Germany so parts store is out of the question. Just ordered my aussie locker and will need this gasket for the install. Or if you have one laying around I take donations.
Go buy a tube of goo (RTV), thats what I use on D30 covers.
The gasket is just that. You can cut one from a piece of bulk material - or even use the cardboard backer from a legal pad. RTV is the best solution.
It may not break if you take care removing the vac disco, but even if you do, just smear the RTV on and reuse it if you want. The bolts don't get much torque, it's a matter of keeping them from loosening, so the cover shouldn't be warped.
