Cant remember either I've found youtube video who said its 30-40psi, the higher being without vacuum on the regulator. On line guides seem to stress 49 psi which I think is the later XJs.
I've got 29psi at idle and 40 psi with the vacuum disconnected.
I don't think its a fuel supply problem, I've watched it a few times in the morning and pressure never drops low enough to cause this. BTW Now it is no longer stalling out just dropping rpm for a second then back to normal.
My guess is a good seafoam cleaning may fix it.
BTW Did the plugs, cap, rotor and wires with the boys not four months ago with no change to this problem. Then it went away for awhile, now its back and looks like maybe slowly going away.
Idle air control circuit #25 and #15 is speed sensor
I believe there are two speed sensor on this transmission, I forget which is where but the simple one that feeds the speedometer is probably fine and it's the other one you need to swap.
Unless this is a wiring harness problem.
It's nice to get a code hopefully you'll be on the right track.
I don't know why these computer controlled cars can have so many problems that never get recorded or trigger a cel. My starting issue went away and came back in a week. No codes either. My sister has a 2008 vehicle that one time she had to rush kids to the doctor it started and ran like absolute crisp to me it sounded mistimed but never do it again or trigger a code. Other owners reported a similar experience with no solution or explanation . Usually never happens again. Or they trade it in I guess.
