hollywood32
- Rancho Cucamonga, CA
Hell, you're built better than I am and I've never run across anything in Big Bear I couldn't do.
I considered mentioning sledge as well, but as I'm apparently still trying to master fire roads, I didnt feel comfortable commiting him to that.
Rear is a 44. Thanks for the info man, Ill see what happens. Also, I could care lass about body damage.You have gears? Make sure you have appropriate spare parts.
What rear? As long as its not a 27 spline or less rear, you should be fine for Tackhammer/LBJ, Clawhammer, or the bunny runs. Maybe aftershock with the right lead and if you're a good driver, but i hear its pretty tore up right now.
The entire point of Goatfest is to get the guys who don't usually get to run hammer trails out on to the hammer trails; but at the same time we DO have to make sure we aren't creating a problem for us and destroying your jeep.
As far as SoCalFest goes .. yeah, apparently there were some problems there. A guy on a stock rig showed up and was told there was not a trail for him to run, he should find a passenger seat. I think they had the wrong guys doing the runs, who set unrealistic requirements so they wouldnt have to actually do any work.
my jeep is just not built enough.Why out?
Ehh im out..
Is Bullfrog going to be a run at goatfest?
I do not have a rear locker. What trials would ok for that setup? I just dont want to drive 4 hours and run the super easy, bunny trails!
Dude just go, I did tackhammer and lower big johnson on 33" tires and stock 3.55 gears. It was still a blast to run only 2 trails. Plus there's sooo many other things u could do!Is Bullfrog going to be a run at goatfest?
Well, I guess I'm out for leading a run at Bullfrog, I need to learn that trail a little better before I lead a large group thru it.
