- Chino Valley, AZ
I am placing my post in this forum because I’m figuring a fabricators mind would be the best to answer my question. Sorry if I was wrong…
Here is the problem:
When I enter a corner, while flat towing, the lead vehicle leans/rolls an uncomfortable amount. Not dangerous, just uncomfortable.
Here is the issue:
Because the towed vehicle is lifted, the tow bar mounts are located high. Based on the simple theory of leverage and center of gravity, a lower mount position should eliminate/lessen the issue.
Here is my question:
Would mounting the tow bar lower on the towed vehicle and lower on the lead vehicle, eliminate this issue? But where would be a good location... For Example, the axle would be the lowest location. If you connected your tow bar to the axle; what would be the negative issues to this setup? I use to tow my 67 Baja Bug by the axle. Can I tow my XJ by the axle?
Description of current set up:
Lead Vehicle
2006, WK Overland, 4x4
Scaled weight at truck scale is: 4980 pounds
Stock height, Stock tires
6”riser receiver is required to maintain a level tow bar configuration.
Towed Vehicle
1988, XJ Pioneer, 4x4
Scaled weight at truck scale is: 3840 pounds
6” lift & 35” Baja Claw Tires
Tow bar currently mounted to the lowest point of the bumper.
Here is the issue:
Lead Vehicle
Towed Vehicle
