Note that all this frame stiffening and plating is great, but our old un-plated car never cracked or broke a rail. IMHO, cage and overall structure is more important than these frame plates. The biggest problem area is the spring bucket. That was a constant battle of realigning the bump cans because the pockets kept deforming. And if you are already cracking, there is very little you can do to save it.
No, I'm not pulling on it - that is the extent of the deformation.
Look at the back side of the bucket -
Cracks, failing spot welds, entire fenderwell structure was failing.
A couple of the trans tunnel - she was a twistin and a tweakin...
