billyjp2
- Indian Orchard MA
nope. doing it once, doing it right. i like building stuff just as much as i like wheeling.
and that could be your downfall
motor is out of 93 will get new seals and gaskets, then go into 98, i stilol got lift parts layin around, if they dont sell they will make there way into the 98 along with 31's of sortsuh put engine from 93 into 98, drive to nac fest, ride beotch
i know it aint gonna happen but if the 95 was to make it heres the list
frt 60, gears, locker, mounts, steering, drive flanges, 35 spline stubs
rear 70, weld diff, mounts, brakes
install trans from 93
buy and install atlas
driveshafts
bumpers sliders and cage
skids
floors
buy tow rig and trailer
maybee i should sell a kidney and a lung so i can take the 95 to nacfest
finish rear bumper and put that on
put in new front shafts
winch controls
disc conversion
WJ booster/MC swap Done, just needs bled one more time
new drag link done
figure out why my ARB doesn't work Done (air line got pinched under gas tank skid)
heres my list
install front and rear axles-Bought front and rear
front tow hooks
rock rails
fix cb wiring
gas tank skid
t-case skid
buy front bumper
...all i can think of for now
Looks like my list has changed a bit too. And I know there is no way I can get gears in time for this so I'm just going to be in 3rd driving down there and floored the entire time in the park.-Install upper and lower arms(Done)
-Front Aussie
-SYE(Pending)
-Tranny cooler
-Tie in front and rear bumpers
-Bumpstops
buy and install atlas Orderd
driveshafts
skids
floors
So did you sell the kidney or the lung? .!..!.
That's cool... by the way... I sincerely hope you finish your build, and I wish you the best of luck with it... Buttttt if you end up parting it out instead, DIBS on the Atlas
That is not what you want. You would much rather see my awesome rig that hasn't done any real wheeling in 3 years with an atlas..if i part it out im so putting the atlas in the 98. i be so awsome to have a dd on 31's with a atlas
so i need 5 steering stabling things?
Getting closer... still a lot to do.Here's the full list, I think I probably left out a few minor things. Lot of work to do before a shakedown run.
To do/build:
PSC Hydro Steering - AXLE SIDE DONE
Panhard - DONE
Front Bumper
Front fenders (sheetmetal and bars)
Entire fuel system (cell, pump, reg, lines)
Entire brake system (MC, lines, etc)
Front driveshaft (cut down a stocker for now)
Re-gear front D60 - Cleaned prepped and ready
Plate and mount steering knuckles - DONE
Final assembly both axles - REAR DONE
Cover hole in pass floor from link mount
Belly pan
Skin rockers
Paint interior
Remount seats, harnesses, etc
Exhaust
To do/buy:
Front spindles - PURCHASED
Rear driveshaft
Trans Cooler - PURCHASED
Triple rate springs/sliders
Brake hoses - PURCHASED
Mopar TPS and IAC - Ross hooking me up for the TPS, IAC I found a spare.
CSF 3-Core Radiator - PURCHASED
3/8" UHMW
Winch (optional)
Misc Hardware
Battery
Exhaust - PURCHASED
Man I check one off and I add another. Soon my list is going to turn into Rob's.:rattle:-Install upper and lower arms(Done)
-Front Aussie
-SYE(Done)
-Tranny cooler
-Bumpstops
-Trim front fenders
