The Cure for your Tie Rod Roll!
Yes, but your answer about the Currie tie rod was kind of cryptic. Simply, I have Currie steering, not prepared to get rid of it. Which "cure" fits the Currie tie rod?
I'm sorry it wasn't obvious. We make these for 2 tapered pin diameters. The stock XJ 5/8" and the larger 3/4". If your Currie steering was plug and play on an XJ axle it is the 5/8" you need if you use the Currie Y link style TRE's. If it is larger the 3/4" is for you. These are only for Y link or the Inverted T style steering.
unnecessary on the currie tie-rod. it has a direct pitman-knuckle connection and a slotted pin on the passenger knuckle, which already does what this "cure" would.
