Destroyer
- Milton, GA
Heavy duty inverted Y steering: Gusseted TJ drag link and 1.5 x .25" DOM tie rod. Believed to be 3/4ton Dodge TRE's, match stock XJ taper. Drag link could use new dust boots. Tie rod nearly brand new. -$125
Garvin/Defender roof rack: 54x72" gutter mount, includes lockable spare tire mount. Also have homemade light tabs and hi-lift brand jack mount if you want them. Lights/CB antenna not included. Tiny surface rust in spots, very good condition. Have all the hardware and rubber pads for the gutter mounts. Over $800 new. -$500
Reamer and Taps: SnapOn R121 reamer and E-taps 7/8-18 LH/RH taps. Perfect for making your own 1-ton steering. Reamer used 4 times, each tap twice, perfect condition. Over $150 new. -$ 120
Stock XJ tie rod/drag link: ~60k miles on it, in good condition. -$35
Stock '99 roof rails -make offer
Stock '99 Dana 30 knuckles and brakes -make offer
Will also have a set of 22" SS front brakelines (RE1550) available soon.
Located just north 20 min north of ATL, zip 30004. Paypal/cash only.
Thanks for looking
-Destroyer
Thanks for looking
-Destroyer
