nhrocker
Jackstand wheeler
- Claremont, NH
Some Jeep parts, a little audio stuff.
(click pics for larger view)
Rancho RS5000 front XJ shocks for ~3" lift
95 Intake plenum
Rear XJ Hidden Hitch, taken off before I really got into wheeling, very little surface rust. I believe I still have most if not all the original hardware kicking around.
Stock rear nut strips, out of early 90's rig
Epiphone Bass practice amp, 8" woofer
Subwoofer box, truck style. Made to hold two 10" subs, has spring/banana clip style speaker cable hookups
Spicer Dana 44 .150" thick diff cover, was purchased new for my rear 44, took it off after only a few wheeling trips. Have all original bolts to go with it. Only has wear on bottom edge from dragging rear diff, cover itself is in perfect shape.
Speaker boxes for 5.25" speakers, 1/2" thick MDF coated in spray on truck bed coating, spring style speaker wire hookups
Also have:
Stock XJ air filter box
Stock TJ air filter box
NP231 main shaft, rear sections (replaced with SYE, good for putting a case back to stock or use for hack n'tap if you mess up yours)
Trades considered for a complete wiring harness from a 91-96 XJ, fuel cell, complete 97+ gas tank/filter/pump assembly, winch...
PM me any offers. Thanks!
95 Intake plenum
Also have:
