RWKHausSupply
- yorba linda, Cali
For a limited Time only.
Spartan Locker for the Dana 30.
The strongest, easiest to install, and only insert locker to include a hardened cross shaft and new roll pin.
$220
Use coupon code RWKSPARTAN
The Spartan Locker, by USA Standard Gear, provides reliable traction at a low cost. Give your vehicle great traction and save some cash. Choose a Spartan Locker for better traction. The Spartan locker by USA standard gear is a mechanical locker that replaces the spiders in a standard case. The Spartan locker's design does not use the thrust washers and has a revolutionary spring and pin design that makes installation a snap! The couplers and drivers are made from 9310 steel, for added strength.
Each Spartan locker carries a one year warranty against defect.
•Fits Dana Spicer 30 with 27 spline axles
•Made from 9310 steel for added strength
•Replaces the spiders in a standard carrier case
RWK Haus Supply
[email protected]
714-875-2414
www.RWKHausSupply.com
$220
RWK Haus Supply
[email protected]
714-875-2414
