jsparhwk
- Richmond, VA
hello all,
I've had a few years off from Jeep life, the Sparhwk (99 Cherokee, 3” lift & 33s) was totaled a few years ago, I saved the drivetrain to put in a new body pulled the engine apart and life just got it the way and the roller I found to swap the engine into had its fair share of rust.... so I still have that and may end up using the body as parts if I can get storage for it. that retired thread can be found here.... :arrowr:
https://naxja.org/forum/showthread.php?t=1122571&highlight=sparhwk
but onto new ventures
I picked up a 97 Cherokee the other week for a steal, it was very clean except for some rocker panel rust in front of the drivers side rear tire.
It was so clean I almost wanted to make it a slightly modified restore. at time of purchase it only had one CEL of P1491 which is just a fan relay,
However I have found some other issues along the way that have made me rethink that plan.
the problem spots, so far....not really worried about the rear bumper,
the rockers I will take steps to stop the rust and decide if it should be repaired or replaced with 2x8 steel, but other than those 2 spots its fairly clean underneath.
But the following is a build thread for the Sparhwk 3.0, I am going to be trying to do everything ‘More correctly’ (as money allows)
and welcome any input or opinions.
