O-Gauge Steamer
- Colorado Springs, Colorado
Me too. Also even... You might say, eagerly awaiting results.
Actually I'm good. I just received a .pdf. No worries, and thank you.
I recently installed this kit in my jeep and I did the "hot rod" setting, I had to back down the transmission cable on the throttle body because with it in the stock setting it would bark 33x12.50 tires on the 1-2 shift, even with my clapped out stock motor. But overall it really woke up the shifts in the trans, it no longer lazily goes from gear to gear.
Wow Sideways! but you using you xj as daly drive? Has the installation for much time?
Maybe the "Truck/offroad" settings are best configuration for a daly driver user?
thank you for your feedback
I did halfway between the two. I had the right size drill bit, it shifts perfect and is a big improvement in overall shift quality.
