Muad'Dib
- Bend, Oregon
Does anyone know what the output voltage is for the B+ Latched output on pin B10 at the ECU?
Ive tested it at the ECU (B10), the Diagnostic Connector (D2-12) and at the B+ latch relay (pins 4 and 5) and in all places i am only reading a little over 10 volts. I suspect that this is suppose to be 12v but i wanted to check.
If no one knows, will someone please throw a volt meter on thier diagnostic connector (D2-12) and tell me what the voltage is?
Thanks so much
Thanks so much
