Derale model # 13700 remote mount oil cooler
Note; This is the 16 pass unit and the fan can be run as a pusher or puller per Derale's web site instructions.
It was VERY / slightly short term used and has traces of trans fluid in it.
(pics of actual unit coming soon)
I am open to "sensible" offers, location Covina CA.
Derale's Electra-Cool remote fluid coolers combine a high-capacity oil cooler core with a Tornado 10 in. electric fan for maximum cooling in any environment. This superior combination will give you the peace of mind of knowing that your fluids will be at their prime operating temperatures. These coolers feature a core with 1/2 in. copper tubes and 3/4 in. aluminum fins with plastic edge-guard protectors, all with a durable black powdercoated finish. Each fan is solidly mounted to the cooler core with clear anodized billet aluminum brackets to ensure a stable attachment. These coolers come in 8 or 16-pass models with your choice of AN-type inlets and outlets. You can make these coolers even better with the fan thermostats and installation kits that are sold separately.
Overall Height (in):11.500 in.
Overall Width (in):15.750 in.
Overall Thickness (in):5.000 in.
Cooler Construction:Tube and fin
Cooler Material:Copper/Aluminum
Cooler Finish:Black painted
Fan Quantity:Single
Maximum Fan CFM:650 cfm
Fan Diameter (in):10.000 in.
Inlet Size:-6 AN
Inlet Attachment:Male threads
Outlet Size:-6 AN
Outlet Attachment:Male threads
Number of Cooling Rows:16
Core Height (in):10.000 in.
Core Width (in):12.375 in.
Core Thickness (in):1.750 in.
Fan Quantity:Single
Inlet Size:-6 AN
Outlet Size:-6 AN
