Hi all, I tried posting this yesterday but it never uploaded, not sure if it was a mistake on my end so I'll try again.
I've got a 98 XJ 4.0 that came with Remote Keyless Entry per the build sheet. Last owner did not give me a fob. I pulled the board out and it's this one which I'm pretty sure is IR (right?). Anyway I went out and bought an RF RKE with programmed fobs, thinking I could splice together the right wires and upgrade.
Well the new board and the old board in the dome light do not have the same connectors of course, and I'm getting lost trying to map the two pin outs together.
This guy had the exact same problem with the exact same two interfaces, but the response to him only points out the wiring diagram and I can't translate between them.
This other guy tried to wire it up under the drivers side kick panel, but I'm failing to see why it can't go over head?
Again I'm just confused as to how to map the 9 wires from the 12-pin connectors on my OEM RKE (post 6 here) to these new 11 wires on the aftermarket RKE board (pinout is here).
Thanks in advance.
Thanks in advance.
