truckeejeeper
- Northern California
Ok - so I just replaced my rotors and pads up front. Brakes worked ok before but were definitely worn. Drove about 10m and jeep started pulling to the left and smelled brake burning. By the time I could pull over and stop (1m) Smoke was coming from drvr side front brakes. Left jeep overnite to cool and got it home fine next day, just being easy on brakes.
So, if caliper locks when heated up, but releases when cold, is this a brake fluid issue? Moisture? It was just one side, and nothing else changed. Does this indicate it's not mechanical? Knuckles were replaced about 30k miles ago. VERY slight markings on new ones but not grooved really, and regreased contact points. Change brake fluid maybe?
One other thing, for about a year now, when jeep is off and I pump the brake pedal, I hear a "whoosh" of air, I don't remember that before. Or am I wrong. I sound like an air leak in the brake booster system, but I can't remember if that's normal or not. I don't see any leaks but need to dig deeper.
I did search for the stuck caliper issue but not much coming up for "releases when cold." It seems odd that it would just start happening all of a sudden with new rotors and pads. Calipers were fine before that. What's going on here exactly
Appreciate any thoughts thx much
