Vanimal
- escondido, ca
The first time we finished that race, I was so exhausted that I broke down and cried at the finish line.
Menopause is a bitch, huh.
Why? Too hard to turn on a switch? Seems like another opportunity for a failure. IMHOOK. It's time for automatic headlights.
I'm thinking this kit:
http://a.co/5iYkMHT
Anyone have any experiance on this front?
Dallas had the shackles from his MJ sitting around, so while it was up on the lift I tossed them on the rear.
Tie rod is available here:
http://www.stinkyfab.com/vehicle-sp...75-aluminum-xj-tj-zj-replacement-tie-rod.html
1" solid 7075. Probably about the same strength as a ZJ tie rod, except that it bends back and uses factory XJ ends, so easier to keep track of stuff.
Intentionally didn't buy a steering damper, wanted an honest feel for how the front end feels. I planned to add one later, but I may leave it off just to drive rockclimber crazy.
Stance with the new leafs and coils:
Been driving it for a couple of weeks now, its a whole new car. I'm a driveshaft and bolting shifters in away from 4 wheel drive, which is nice too, but still mostly incidental.
The coils were a game changer, really softened up the front end. Now I just need to order up some Bilstein shocks and add a couple of hundred horsepower under the hood.
I'd skip the Bilstein's. I have a couple sets and don't like them, way to harsh over road bumps, etc.
I wouldn't. I have had several sets and they ride better than anything you could ever imagine.
But you have to have the right shock and spring for your car. I have a pretty good idea at this point how to get the ride I want out of an XJ with Bilsteins.
Is it mostly the rear that feels that way?
I can tell you up front those coils are way too soft. Tell me that's not counter intuitive..
The rear sounds like the shackle angle is WAY off.
You you want your shackle pointing to the back at 30-45 degrees depending on how much uptravel you have. Is it fairly strait up and down?
I go back about 8 posts to mentioning needing the right shock and spring for your car.
Spring includes leaf, shackle, and their combined mounts and geometry.
You can go from bad to worse still using the right parts..
