snowboard3r411
- Palisade
97 SE 4dr 4.0/Auto unknown actual mileage but likely around 180K. (warning light cluster was swapped out for a gauge cluster).
-D300 t-case, flipped, cable twin-stick shifter.
-Custom tube winch bumper with Warn 9500hs winch, synthetic fairlead.
-LeBaron hood vents and aftermarket CAI
-BIGoffroad head light harness
-D&C full roll cage with added floor tubes and "B" hoop bracing
-4-point harnesses and high bolster aftermarket vinyl seats.
-Kenwood Stereo, factory rear sound bar
-Manual windows/mirrors
-Full size 35" spare
-NEW 35x12.50/15 Mickey Thompson MTZ's on beadlocks and 4 new lock rings, Spidertrax 1.25" wheel spacers
-D30 w/ 4:56's, lunchbox locker, inner alloy shafts, Yukon u-joints,axle truss and LCA skids
-Rock Crawler 3-link brackets and custom links with HUGE joints.
-Phat Jeeps Canyon Climber steering
-RE 6" coils, 1.5" spacer
-RE HD Trackbar and bracket
-JKS Over Axle Bracket
-Bilstein 5150 shocks on all 4 corners, Daystar EVS foam shock bumps on fronts
-D44 rear axle, alloys, Detroit EZ, 4:56's
-BIGoffroad 4" FlexE leafs and RE boomerang shackles, 3-position spring seats and raised shock mounts welded on.
-"Solid" diff covers
-Full frame stiffeners with welded on sliders.
-Custom rear bumper
-Flat belly trans crossmember
-Factory gas skid
-Rear quarter guards
-Custom rear bumper
-Factory gas skid
