muddypunk
TOOL
- Coupeville Whidbey Island washington
I am thinking of putting on this power steering cooler that I got off a chev truck and I am wondering if it is just a waste of time
Yeah, that's a good idea, it will improve the life of the pump.I am thinking of putting on this power steering cooler that I got off a chev truck and I am wondering if it is just a waste of time
Anybody ever checked if the reservoirs can be swapped between the models?
just had to pull my motor again so i will get you some picturespics or it didn't happen
Well, I bought a rolled 01' GC limited for the drivetrain for my buggy.
That is were we sourced the pump.
I would bet it is VERY cheap at a junkyard... $10-$20?
Nothing else is needed!
Don't forget to score the high pressure hose. The fitting on the end is different than all others and every hose house I contacted couldn't make the bump tube for the larger steel line.
Are you talking about the fitting that is already screwed into the pump that the hose then screws into?all you have to do in unscrew the high pres fitting from the WJ unit and use the one from your XJ.
