- Cincinnati, OH
After beating on my Xj for a few years without any reinforcements (frame, sliders, ect) it is finally time to fix it correctly and add a cage. This also my first time major fabrication project so I welcome alll constructive criticism and suggestiosns. With that said ignore the crappy welds... I'm learning as I go.
The project begins after breaking the ears off of the steering box and susiquently giving the jeep a little haircut at Harlan in September.
picture during trip
Picture just before getting towed out (thanks again Matt).
TO do List:
1) Install HD offroad Engineering frame stiffners
2) Replace rockers to act as a base to the cage build
3) Cage
Frame Stiffners:
I will not bore you with another Stiffner Install How to. For all of those who question whether stiffners are necessary or not. Take a look at some of the damage that to my rails that I found while Installing the stiffners. There was similiar damage on both the driver and Passenger side where the sheet metal making up the unibody was torn around the welds securing the drop bracket braces to the frame.
Pictures of the damaged cleaned up.
Damaged areas were patched with new metal and the stiffners installed:
Picture after trepair and the sitffner Install.
Jim
picture during trip
TO do List:
3) Cage
Frame Stiffners:
Jim
