mscans
- west palm beach, florida
so, i have never tore apart a differential. my pinion is very loose.
could i replace this bearing and use the stock shims and probably be okay?
i understand the new bearing needs to be pressed on, probably by a shop.
could i go to the junkyard, pull a pinion with the pressed bearing out of a good tight differential dana 30, install that in my dana, and it work out properly?
dailydriven, 4.5 rough country. 87 pioneer.
