Here's a current list with prices on parts that I have on hand. If you have a specific request let me know, I may have it just not included it yet.
Bulbs Misc light bulbs Inventory Good $1.00 Jeep XJ
HO knock sensor knock sensor 4.0L HO Inventory Good $2.00 Jeep XJ
Buzzer mod. Buzzer module Inventory Satisfactory $2.00 Jeep XJ
Timing chain cover gasket Inventory New $5.00 Jeep 4.0L
Dip stick 4.0L dip stick Inventory Satisfactory $5.00 Jeep 4.0L
Head bolts HO motor Inventory Satisfactory $5.00 Jeep 4.0L
Digital clock Interior Digital clock Inventory Satisfactory $5.00 Jeep XJ
Wiper switch Interior rear wiper switch Inventory Satisfactory $5.00 Jeep XJ
Hood light Under hood light Inventory Satisfactory $5.00 Jeep XJ
Glove box light Glove box light/clasp Inventory Satisfactory $5.00 Jeep XJ
Trans/Wiper switch comfort and wiper switch Inventory Satisfactory $5.00 Jeep XJ
Cig lighter Cig lighter and internal mount Inventory Satisfactory $5.00 Jeep XJ
Fill tube Fuel tank fill tube Inventory Satisfactory $5.00 jeep XJ
Bump stops Rear Xj bump stops Inventory Satisfactory $5.00 Jeep XJ
Battery hold down Battery hold down bracket w/o bolts Inventory Satisfactory $5.00 Jeep XJ,Mj
Dip stick tube 4.0L dipstick Tube with Dipstick Inventory Satisfactory $5.00 Jeep 4.0L
Belt tensioner 4.0L belt tensioner bracket Inventory Satisfactory $5.00 Jeep 4.0l
Engine mount bracket 4.0L Engine mount bracket Inventory Satisfactory $5.00 Jeep 4.0L
Alternator bracket 4.0L Inner and outter alternator brackets Inventory Satisfactory $5.00 Jeep 4.0L
Fan w/clutch 4.0L Mechanical fan w/clutch Inventory Satisfactory $5.00 Jeep 4.0L
water pump pulley 4.0L water pump pulley Inventory Satisfactory $5.00 Jeep 4.0L
Hatch shock Rear Hatch shock Inventory Satisfactory $5.00 Jeep 4.0L
EGR tube 4.0L Renix EGR tube inventory Satisfactory $5.00 Jeep 4.0L
Battery hold down bar battery hold down bar Inventory Satisfactory $5.00 Jeep XJ,MJ
Injector O rings O rings Inventory New $7.00 Jeep 4.0L
valve cover gasket gasket Inventory New $10.00 Jeep 4.0L
Oil pan gasket gasket Inventory New $10.00 Jeep 4.0L
Distributer square plug Inventory Good $10.00 Jeep 4.0L
LH mirror exterior door mirror Inventory Good $10.00 Jeep XJ
TCU Transmission control unit AW4 Inventory Good $10.00 Jeep XJ
Cruze module cruze control module Inventory Good $10.00 Jeep XJ
Headlight switch headlight control switch Inventory Good $10.00 Jeep XJ
Shift indicator Aw4 shift indicator Inventory Good $10.00 Jeep XJ
A/C control panel Interior A/C control switch panel Inventory Good $10.00 Jeep XJ
Shifter boot Shifter boot Inventory Satisfactory $10.00 Jeep YJ
E-brake handle E-brake handle assembly Inventory Satisfactory $10.00 Jeep XJ
Seat belts Tan rear seatbelts Inventory Satisfactory $10.00 Jeep XJ
Throttle pedal Throttle pedal assembly Inventory Satisfactory $10.00 jeep XJ
Vac canister Vac canister bottle Inventory Satisfactory $10.00 Jeep XJ,MJ
Roll over valve Misc Roll over valve Inventory Satisfactory $10.00 Misc Misc
Ash tray maroon Ash tray Inventory Satisfactory $10.00 Jeep XJ,MJ
Pressure bottle Pressure tank and mount w/cap Inventory Satisfactory $10.00 Jeep XJ,MJ
Battey hold down Complete hold down bracket w/bolts Inventory Satisfactory $10.00 jeep XJ,MJ
Valve cover 4.0L valve cover Inventory Satisfactory $10.00 Jeep 4.0L
Air filter assem. 2.8L v6 air filter assembly Inventory Satisfactory $10.00 jeep 2.8L
Power steering pump 2.8L power steering pump and bracket Inventory Satisfactory $10.00 Jeep 2.8L
Power steering mount 4.0L power steering pump mount Inventory Satisfactory $10.00 Jeep 4.0L
Fan mount 4.0L fan blade mount Inventory Satisfactory $10.00 Jeep 4.0L
Pulley Ribbed pulley Inventory Satisfactory $10.00 jeep 4.0l
Pulley Smooth pulley Inventory Satisfactory $10.00 jeep 4.0L
Power steering pump Power steering pump w/o res Inventory Satisfactory $10.00 Jeep 4.0L
Axle brake line Rear D35/8.25 Axle brake line Inventory Satisfactory $10.00 Jeep D35/8.25
Throttle cable mount Mount to throttle body Renix Inventory Satisfactory $10.00 Jeep XJ,MJ
D30 Diff cover D30 diff cover Inventory Satisfactory $10.00 Jeep D30
Lock accuator Door lock actuator Inventory Satisfactory $10.00 Jeep XJ,MJ
Starter 4.0L starter Inventory Satisfactory $10.00 Jeep 4.0L
Motor plate 4.0L Motor plate Inventory Satisfactory $10.00 jeep 4.0L
Injectors HO 4.0L Inventory Satisfactory $15.00 Jeep 4.0L
Dsitributer 97+ 4.0L distributer Inventory Satisfactory $15.00 Jeep 4.0L
Wing windows LH wing windows stationary Inventory Satisfactory $15.00 Jeep XJ,MJ
Battery Tray RH Battery tray Inventory Satisfactory $15.00 Jeep XJ,MJ
Brake caliper D30 Brake caliper Inventory Satisfactory $15.00 Jeep Bendix
Speedo Gear 31,33,34,35 Inventory Satisfactory $18.00 Jeep NP231
Fuel pump Bosch fuel pump Inventory Satisfactory $20.00 Jeep 4.0L
relay panel Under hood relay panel 97+ Inventory Satisfactory $20.00 Jeep 4.0L
Brake pedal ***. 92-96 brake pedal assembly Inventory Satisfactory $20.00 Jeep XJ
T/C shifter lever Transfer case shifter lever Parts Satisfactory $20.00 Jeep CJ,TJ,XJ,MJ
Throttle body 4.0L Renix Throttle body Inventory Satisfactory $20.00 Jeep 4.0L
Battery Box After market Battery Box Inventory Satisfactory $20.00 misc Misc
Power steering pump 4.0L power steering pump w res inventory Satisfactory $20.00 Jeep 4.0L
Sway bar links lifted sway bar links inventory Satisfactory $20.00 misc D30
track bar bracket Drop track bar bracket for lift inventory Satisfactory $20.00 misc D30
Window regulator Window regulator w scissor Inventory Satisfactory $20.00 Jeep XJ,MJ
Intake manifold Renix 4.0L intake manifold Inventory Satisfactory $20.00 Jeep 4.0L
intake manifold HO 4.0L intake manifold inventory Satisfactory $20.00 Jeep 4.0L
Power steering pump 4.0L power steering pump w mount Inventory Satisfactory $25.00 Jeep 4.0L
Throttle body 4.0L HO Throttle body Inventory Satisfactory $30.00 jeep 4.0L
Knuckles D30 knuckles Inventory Satisfactory $30.00 Dana D30
Gauge cluster XJ,MJ full gauge cluster 222K miles Inventory Satisfactory $40.00 Jeep XJ,MJ
