squashman702
- Brighton, MA
Have a bunch of miscellaneous stuff that I need to get rid of. All parts located in MA. I can accept paypal and can usually ship next day.
5.9 Amp- 180 watts instead of the standard 120 watt Infinity. Comes with 6" of harness in case you wanted to splice into a non-5.9 ZJ, worked when pulled. Don't have a picture of this at the moment. $30 plus ship.
5.9 leather transfer case shifter. Really nice shape. Don't have a picture at the moment. $20 plus ship.
5.9 side skirts. Decent shape, no structural damage, but I would reccomend repainting to cover up rock chips, etc. $50 plus ship.
ZJ front tow hooks. Brackets stripped and primed, comes with all new G8 hardware, but no nut plates for the inner frame rails. Ran a pair of hooks like that for years without issue. Hooks are slightly different (one is slightly more pointy than the other) but bolt right up. Don't have pictures of these. $45 plus ship.
Clayton's belly skid for ZJ. Brand new, never mounted. Slight surface rust from sitting around. Comes with all hardware. Would strongly prefer pickup on this one. $150.
Rubicon Express Extreme Duty trackbar and bracket for ZJ, TJ, XJ, MJ, LJ. Bushings and johnny joints replaced within the last few thousand miles. Works with 4.5"+ of lift, comes with an additional johnny joint for 6.5"+ of lift. Same as the link below- no pictures, sorry. $160 plus ship.
http://www.rubiconexpress.com/Lift-Kits-Suspensions-Shocks/Track-Bar-Bracket-Front-XJ-ZJ-4-5-7-5.aspx?t_c=1&t_s=101&t_pt=4303&t_pn=R%2fERE1665[/URL]
http://www.rubiconexpress.com/Lift-Kits-Suspensions-Shocks/Track-Bar-Adjustable-Extreme-Duty-Front-XJ-ZJ-4-5-7-5.aspx?t_c=1&t_s=101&t_pt=4164&t_pn=R%2fERE1660[/URL]
WJ Overland armrest. Decent shape, needs to be cleaned some. Shows some wear and has two pinholes in the top. Tough to find. $60 plus ship.
ZJ NP231 bezel. Very rare, nice shape. Around $40 on eBay if you can find them. Spot between the 2WD and 4HI is dirt, washed it off already. $25 shipped.
Olds Aurora backup lights/plate frames. Have 2, no pictures, sorry. $20 plus ship each.
