Dan Fredrickson
- Sacramento, CA
Time TO Do It Right !!
Those are the onesI'm getting ready to do a WJ knuckle/ brake swap. I want to do it right & upgrade the steering/ TB at the same time on my 99 XJ with stock D30 front axle.
I believe I need the Axle Offset Bracket & the Frame Inside Bracket but just wanted to confirm that first. Thanks in advance
This test is really easy and very worthwhile. Get under it while a friend turns the wheel back and forth and watch the Tie Rod fight the Panhard...If that outside corner rises into a turn you are binding, put in in park and check it out!
