I took some time today in the garage and got some work done and reached some milestones.
The uppers are burned in, the lower bar mounts are bolted in, front cups drilled out, bags in.......AND IT RAISED ALL BY ITSELF TODAY!! First time, frame off the ground under her own power. I am very pleased. Sorry it was dark but I took some pics...and a video
Heres the front clip I am working with.
These are the front bags at 110 psi (shop air)
I just realised I didn't take a pic of the rear bags under pressure :anon:
This is it aired up on 100 psi all around. Pretty decent lift for 100 psi!! I am running 200 psi onboard air, so it should be ridiculous.
The only problem is the lower bar mounts are hitting the bars under large lift. So I have to re drill and angle them another 25 or 30 degrees to clear, no big deal. The 4 link is adjusted, and pinion angle is set. 4 link doesn't bind, front rad arms don't bind.
And I had to have some fun...its bad karma not to crush some cans the first time it lifts.
The tall boy was with the driver tie rod installed (prevents the frame from laying) and just the front aired down.
ENJOY! I have a vid but its really dark, I'll do a reshoot tommorow.
