xL8 APEKSx said:...what other options do I have under $1000? I'm not very handy with DIY/JY stuff as I don't have any experience with the XJ yet, and I have only met one or two local guys so I'm not sure who I could sucker into helping me out with some labor (I coudn't go pull an 8.25 and swap it out by myself).
Sure you could. Can you change a tire? It's not much more difficult to pull and axle.
Pull tires
Remove U-bolts
Remove drive shaft
Remove shocks
Remove brake lines
Remove e-brake cables
Need about 5 tools to do it. 3/4 or 19mm Socket or wrench for lugnuts and u-bolts, 8mm socket or wrench for driveshaft, 15 or 17mm socket or wrench for shock bolts, whatever wrech for brakeline
Start scrounging the PAP for a Dana44 they can be had for $150-$200. There's 2 here right in OC, another 5-10 w/in 50 miles.
