Hi all
I have just rebuilt a 4.0 for the XJ and i was just priming the engine oil before install.
Problem is I'm getting no oil at the top end.
I am using a drill on the pump through the dizzy hole.
if i remove the oil pressure sender i get a good amount of oil out of it.
But for several minutes of pumping...nothing at the rockers.
I installed new lifters which i filled with oil.
I am using penrite running in oil.
The rod tubes aren't blocked. I checked on install.
It's a new high volume pump.
I really don't understand and it's supposed to be going in this weekend.
Any ideas please?
Any ideas please?
