New Warn Rear Bumper for XJ
XJ_Goat
Utah
--Brand New Never Installed--
Warn Rear Bumper for Jeep Cherokee, XJ
Will sell for $450 or may trade for a locking diff - Chrysler 8.25 29 spline rear axle. (This bumper retails for $800+)
I bought this in a package deal and do not need this. While new it does have some minor wear and tear just from being moved around on the garage floor, comes as is, no mounting hardware.
Factory description: The WARN Rear Bumper for the Jeep Cherokee is designed with off-road performance in mind. This bumper sits high and tight, and is sloped to maximize departure angles and ground clearance. Welded eyelets will mount D-shackles, creating anchor points to increase your vehicle recovery options.
The bumper is constructed of 3/16" and 1/4" steel that is laser cut, CNC formed and robotically welded for precise fit and durability. Available in black powder coat finish. Compatible with factory and aftermarket rear receivers.
Available for pick up in South Weber – zip 84405. Please text 850-865-2205 for more information.
More info can be found here: http://www.quadratec.com/products/78009_80X_A_PG.htm
