highspeed
- Owens Cross Roads, Alabama
I have a RE double shear track bar. I'm getting some movement at the flex joint on the drivers side mount even though the joint is 1 yr old and only has 3 wheeling trips on it. I have tightened the bolt holding the joint as tight as my impact will go. I want to rebuild the joint but can't figure out if the joint is the small or large size listed on RE's website. Anyone know?
Also, I have a RC flex joint spanner wrench and was wondering if it will work on the RE flex joint?
