SanDiegoXJ
- San Diego, CA
Some of you may know that I had an engine rebuilt by Mike Finch some time ago. Since that time, the Jeep has had a vibration it never had before. It had also developed a leak in the front transmission seal and transmission pump seal.
So I pulled the timing cover, valve cover, and oil pan to inspect all the parts I could. Everything seemed to be in order, so nothing was changed except the gaskets. I also dropped the transmission, changed the oil pump, installed a new torque converter and flex plate, and put it all back together.
I started it up today and the engine doesn't want to run. When I crank it, it just rattles and dies. If I give it some gas, it doesn't hold a steady rpm, but increases and decreases harmonically by about 500 RPM. If I move the distributor back one tooth, it idles without assistance, but it backfires and won't go above 2000 rpm.
Anyone got some time to swing by and take a look today or tomorrow? I'd love to get some other opinions.
