pierceME311
- FL "the trailer park of the nation"
Also check out FitchVAs' website, it's full of great how-to's with lots of great XJ knowledge to be had.
www.fitchva.com/jeep/
thanks, my writeup in progress is hereHey sbxj...really nice setup. My Cibies have a similar cutoff but not as good as the lights you chose. Did you happen to take any pics of the headlight install? What bulbs did you install?
If price is a issue go with a harness first even with the stock lights you will see a huge improvment.
I bought this one.
http://www.amazon.com/9003-Heavy-Wa..._7?s=automotive&ie=UTF8&qid=1285027659&sr=1-7
the only dislike I have with it is there is no inline fuse. I did that and the set of auto pals for less then $100 and couldn't be happier with the results. I also did just the harness for a friend and she was completely satisfied with the upgraded light.
Ditto on the Daniel Stern Website
The Jeep lighting is horrible and I decided to bring it up to date....
Infinity FX Bi-Xenon projectors retrofitted into 200mm housings
Total cost of project approx. $450
You do get an increase in brightness with stock harnesses but probably not a good idea to use higher watt bulbs.
They do, but not for that price. I think the going rate is around $750 for the "spitzkraft"
I went with the slightly more expensive superchina harness- which has higher rated relays, but appears identical otherwise. It does include fusible links in lieu of a fuse, but I replaced those with ATC fuse holders to keep things simple (I always have fuses in the Jeep, but not link wire and tools). If you do get this type of harness, keep an eye on the connections to the lamps- some (mine included) have melted and fallen apart.
