I am going to have to go ahead and disagree with you there. Unless by "almost as much" you meant twice as much.
Go ahead an disagree...won't hurt my feelings. :laugh: That's why all of our jeeps are different...............
I said most, cuz the ones I've looked at EXCEPT for TNT still hang below the frame 3-4". Even the cav fab one you posted, and clayton as well, hang down the diameter of the joint + ~ 1"...which means 3-4".
Their saving grace is the arm itself, which lets the vehicle slide over the obstacle, whereas the drop bracket has a much better chance of catching & hanging up.
I haven't actually measured, but I'd say my cad brackets hang below the factory mount points 4-5", but are closer to the tires than the brackets you mention. Personally, I'd rather have something hang down close to the tires than mid frame as it is easier to use the tire to keep the obstacle from sticking with good tire placement. Can't always do that, but most times you can.
That's why IF I go long arms, it will most likely be TNT, along with their matching coil spring conversion for the rear, or the Synergy 4 link front and the IRO 4 link rear.
No biggie, I just mentioned it as unless you wheel in places where they hang up all the time, it's not worth the money or the quirks that can sometimes show with long arms/radius arms.
Simply suggesting a compromise to save some money and still have a nice ride.
