REVROK
- Spring Creek, NV
Kudos on this write up! This might make a good sticky!
cher 96 this is my first post can you explain the taper ends and do you need the whole pack and adjustable shakle for the 5.5 lift?thanks for help
Had a set of 4" fsj rear springs under the deck. Wanted to stretch the wheelbase a bit anyway. Pushed the axle back about 3", moved the shackle hanger back 2" and down 2". Still wrapping up the hp44 swap, so I'll have to get back on how it performs. Shackle sits at 50 degrees, so it should flex well. Also building shock hoops and running 14" bilsteins through the floor, so ride should be night and day from before.
